91 posi in an 89 with a 90 rear?
Old Mar 9, 2004 | 08:46 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
I have an 89 RS with a 90 3.23 rear. Can i use a 91 posi from a 2.73 gear car on my 90 rear end with a 3.23 gear?
Bottom line: can i use a 2.73 posi from a 91 iroc on my 3.23 rear? assuming they both have 28 spline axels.
Old Mar 9, 2004 | 09:14 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The 3.23 gears are 3 series gears, and the posi that has the 2.73s on it is a 2 series carrier. You can use those gears on that posi, if you get a spacer that allows you to run 3 series gears on a 2 series posi. As long as you have the right axles then everything will bolt up correctly, and fit right. Its just a matter of getting the right series gears and posi.
Old Mar 9, 2004 | 10:53 AM
89305RS's Avatar
i thought that the only difference between 2 and 3 series were the carriers. Like 88 and down and 89 and up were all 3 series carriers.
Old Mar 9, 2004 | 11:00 AM
MdFormula350's Avatar
its not really a year thing, more like the ratio that depends on the carrier number.
the year thing could be placed for the axle splines. 89+ had 28 splines. verses 26 from previous years.
Old Mar 9, 2004 | 12:04 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
The difference in the carries is in the gear ratio they use. 2.72 - 3.08 gears are mostly 2 series carrier gears, and 3.23 + are 3 series. So if that carrier has 2.73 gears, I guarentee you its a 2 series carrier. The ring gear on the 2 series setups are thicker than 3 series ring gears... hence why you can't put 3 series gears on a 2 series carrier w/o a spacer.
Companies do make higher ratios for the 2 series carries though. I know Richmond does. They are normally a little more $$ than 3 series gears though. I think about $20.
As said, the axles spline #s can be defined by years, as in 26 spline is up to 89, w/ 89 being the transition year to the 28 splines which was 90 +
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
