TH-350 Tailshaft Housing and Speedo Gears
Old Mar 10, 2004 | 07:45 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I am trying to adjust my speedo gears for the third time. The last time I just gave up. This time I want to get it right.
I think I have the right combo: 15 tooth Drive, 45 tooth Driven, is my target. for 235/60/15 tires and a 3:73 rear end.
The 45 tooth that I have shown as the light blue is way to big. I thought the speedo gears were the same for the TH-350 and 700R4. Is it possible that they are different and I have the one from the 700? Or do I need to find a different housing and drive shaft to go with it so it fits?
Anybody have a clue? Here are some pics.
Thanks!
Attached Thumbnails TH-350 Tailshaft Housing and Speedo Gears-speedogear2a.jpg
Old Mar 10, 2004 | 07:46 AM
Car: YTG Camaro
Engine: 383
here is the other pic
Attached Thumbnails TH-350 Tailshaft Housing and Speedo Gears-speedogears1a.jpg
Old Mar 10, 2004 | 08:17 PM
Nordbert's Avatar
speedo gears
You have the wrong housing. You need a housing from a BOP
(Buick-Olds-Pontiac) tranny. They will accept the 700r-4 adapter
and gear. See you local transmission shop. They should have one. BTW, a th350 w/6" tailhousing is about 3" shorter than a
700r-4, so you will need a longer driveshaft.
Old Mar 11, 2004 | 06:42 AM
Car: YTG Camaro
Engine: 383
Let me get this straight
I should already have the longer drive shaft. When I installed the TH-350 I used a different drive shaft.
The part I am unclear about it the 700R-4 adaptor. What is the adaptor for/do? I have a TH-350 tranny and housing. Am I looking for a 700R-4 BPO - 6" housing? or a TH-350 housing from a BPO that will accept the larger speedo gears?
Old Mar 12, 2004 | 09:42 PM
Nordbert's Avatar
You need the BOP th350 housing that will accept the 700r4 gear, and the adapter with the tooth count of your gear cast onto it. Chevrolet didn't "upgrade" to the larger gear.
Old Mar 17, 2004 | 11:28 AM
Car: YTG Camaro
Engine: 383
the search begins thanks...
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
GTAman
Aug 27, 2015 10:29 PM
