Flex plate to TC bolt hardness specs?
Old Mar 11, 2004 | 11:22 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I just installed my engine and tranny combo into my 87 T/A. When replacing my flexplate to TC bolts (old ones went with old engine) I got a set of 3 hex head "M10 1.50 X 15" with a rating of 10.9 stamped on the head.
The old bolts were rated with a 9.8 on the head and they were the stock pieces. I understand how the american hardness rating works. But the metric stuff is a little different?
I checked it out and did a search on this site and the web and have concluded that a metric bolt with a hardness rating of 10.9 is somewere between a standard grade 5 and grade 8 bolt.
Is this correct?
Also, if this is correct that puts the stock bolt that I pulled out with the 9.8 hardness rating, closer to a grade 5 bolt. Isn't a grade 5 bolt a little too weak to be using in this application, and will a metric 10.9 hard bolt be strong enough?
I am by no means a metallurgist so please give me some insight.
Old Mar 11, 2004 | 12:18 PM
ede's Avatar
ede
you should use bolts made for the flex palte to TC connection and not a standard bolt. as for your question as i understand it the bolt strength goes up in relationship to the diameter and is equall to or exceeds our grade 8. it's not hardness they rate it's tensil strength.
Old Mar 11, 2004 | 05:10 PM
383 rocket bird's Avatar
What I did when I replaced mine was to use ARP bolts. They are purely a fastener company and make high quality bolts better than anything from a hardware store. They are like 7 bucks from summit or jegs. -John
Old Mar 12, 2004 | 08:39 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Thanx for the help. My goal was to make sure that I got a good fastener, and I didn't quite understand the numbers on the top of the head of the bolts. I didn't want to have to crawl under the car on the highway and dig the broken bolts out of the TC on my way to the CC Summer Nats. That would suck.
Old Mar 12, 2004 | 10:23 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The higher the number on top the stronger the bolt is. So replacing a bolt with a higher grade bolt is ok.
evilstuie
Jan 9, 2020 08:29 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
