Driveshafts
Old Mar 11, 2004 | 02:21 PM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
Driveshafts
I tried to search but was not sucessful find the answer. I need to find a on-line address where I can find an LS-1 driveshaft used. I think it was a site that connected a few salvage yards together to locate parts in your specific geographic location. Of cousre I want a new/used LS-1 driveshaft, but I want to use this site to look for parts on my wifes car. Any ideas???
Old Mar 11, 2004 | 02:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car-Part.com. MyPartshop.com.
JamesC
Old Mar 11, 2004 | 03:00 PM
hitman's Avatar
Woo Hoo
Thanks man! :yourock:
Old Mar 11, 2004 | 03:07 PM
JamesC's Avatar
I just noticed you're from Houston--shoot, man, head to North Shepard Road. There must be 20 bone yards along there, and they're all hooked to a hot line (which spiders out well beyond N. Shepard Rd). If the yard you're inquiring at doesn't have your part, they'll find it for you. Come to think of it, Saul's Espana (on Airline, if I remember correctly) has a 1LE shaft in their driveshaft rack out back. I was told they normally went for $45-50.
JamesC
Old Mar 12, 2004 | 08:23 AM
hitman's Avatar
JamesC
$45 - 50 Bucks!!!
I will have to look ASAP! Everywhere I have seen on the net is avg about $125.
1LE just as good as an LS-1??
Old Mar 12, 2004 | 09:45 AM
JamesC's Avatar
I run the 1LE shaft, and though some of the guys will no doubt disagree, I doubt that there's a lot of practical difference.
JamesC
Old Mar 12, 2004 | 11:41 AM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
LS-1 driveshaft has a larger diameter than the 1LE shaft. Also, the LS-1 has a vibration damper on the front yoke, whereas the 1LE does not. IMO, the LS-1 is a better shaft.
Old Mar 12, 2004 | 12:09 PM
JamesC's Avatar
I don't have any experience with the LS1, so I can't comment on its effectiveness. That said, I've always wondered why this shaft had a vibration dampener--if the shaft is properly balanced, why the need? My 1LE shaft demonstrates no sign of vibration at high speed without a dampener. So what gives?
JamesC
Old Mar 12, 2004 | 12:56 PM
hitman's Avatar
1le
The 1LE you have.. is it steel or aluminum?? How do I confirm it is a 1LE DS while at the bone yard?? The LT-1's are aluminum with the damper right??
Old Mar 12, 2004 | 01:10 PM
JamesC's Avatar
The 1LE is alum, so there will be no rust, except on the slip yoke and the U-joints. The part number is on a label fixed to the tail of the shaft, 10085375.
JamesC
Old Apr 5, 2004 | 12:04 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I have one question on the 10085375 driveshaft... Has anybody ordered one of these through GMPartsDirect.com?? And for those who have, does it come with u-joints and yoke, ready to be put in the car??
Old Apr 5, 2004 | 12:23 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I checked and it comes complete and ready to install for about $249. Bought my Aluminum 1LE off e-bay for $115
Old Apr 5, 2004 | 07:17 PM
thirdgen88's Avatar
Car: 1995 Corvette
Cool... Actually, I found an LS1 shaft at a local yard here for $150, in real good shape... actually cured my vibration problem (the tired 250+K mile steel shaft served me well though)...
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
topteam54
Oct 6, 2015 12:21 AM
loud91rs
Oct 5, 2015 10:05 PM
apie2546
Sep 20, 2015 01:03 PM
89newfun
Sep 16, 2015 09:28 AM
