Transmission is out but lines are stuck...
Old Mar 14, 2004 | 11:31 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
Im replacing the flex plate and have the tranny sitten on jack about 2 inches away from flex plate but still need more room, so the trans lines need to be undone, should i unhook from tranny or from the cooler in the front?? on the tranny they are madd hard to get undone n e suggestions?
Old Mar 14, 2004 | 11:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The perfect tool to remove them (without rounding them off) is a 1/2" crows foot on a universal joint connected to about an 8" extension and a 3/8" ratchet (this is to disconnect at the tranny, which I would recommend so you don't have to mess with the little bracket that holds them to the motor, plus you'll have freer movement of the trans and less potential damage to the lines)..
Old Mar 15, 2004 | 09:03 AM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
great thx, ill let ya no how it goes
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
jer4251
Sep 1, 2015 09:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
