How do I tell the what gears
Old Mar 15, 2004 | 11:36 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
How do I tell the what gears and spline I have on my 89 RS coupe?
Is there a code on my vehicle sticker on the door?
Old Mar 16, 2004 | 05:06 AM
ede's Avatar
ede
pull the cover and count teeth ot look for the ratio stamped on the gear set, same with axles, pull one and count splines. 89 was transition year. posting on the correct forum helps too.
Old Mar 16, 2004 | 10:59 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
Check the RPOs in the center console. Should be GU#
Old Mar 16, 2004 | 11:34 AM
ede's Avatar
ede
rpo only tells you waht it left the factory with, not what you have.
Old Mar 16, 2004 | 11:44 AM
Car: 1991 GTA
Well, the hard way is the way then. Go with Ede on this one :lala:
Old Mar 16, 2004 | 12:07 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I have heard that if you take the car, put it in your 1:1 gear, which is 3rd in the A4, and run it at 75 mph, then the rpm should be close to what gear you have. I know it works in my buddies 99 WS6 6 speed, dead on. Its a little more difficult in an auto, caues of converter slippage. Mine was about 100 rpm lower than the 3420 I should have seen.
Old Mar 18, 2004 | 08:00 PM
jimmy_mac's Avatar
If his car is anything like mine, it won't get you real close. Mine has had a couple of trans swaps, since I got it and I know know the rear was rebuilt before I had it. From calculating mine by rpm and tire diameter and mph going, I thought I had 3.73s. Once I took it apart found out I had 3.42s. That's how far off my speedo is. Now after pacing my wife I know it's 5mph off at 75.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
