700R4 Lockup torque converter help, now i need it people...
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ok, so im swappin out the old tired 5.7 tpi to a carbed 350 pushing around 400 horse, but im reusing the 700 cuz i like the overdrive but i ripped out the harness for the tranny since it was on the ECM loop, thats for the lockup torque converter right, thats what i think, so what do i do to fix this, is there a kit that makes it lock up or do i just get a non lockup torque convereter...
I dont care what way i fix it, as long as i get it done....
Transmission: 4L80E/4L80E
Kit available from Summit or Jegs.
Not sure it includes the pieces to replace the harness you cut.
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
If you look in jegs or summit they make pressure switches that you install into the transmission making a ground and locking the torque converter up. I am not sure how they install but I believe they replace a circuit that use to run to the computer.
Car: 87 IROC Z28
...bracket for the carb, what the hell, i have to make one, then....i dont see one for sale anywhere, ima reuse my tpi braket and mount it to teh carb sumhow...
Car: 87 IROC Z28
i have 3 to choose, 2 edelbrocks and a holley, i think ima go with teh 750 holley...i donno the part number
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i know tci and painless make a lockup kit for swapping the 700 to a non ecm car thats not a problem getting... but what the hell is the carb bracket for lol i have a 700 in a carbed engine myself and was planning on getting the painless kit but nobody ever mentioned anything about a bracket
Car: '87 Formula
The bracket he's talking about could be none other than the TV cable to hook up to your carb linkage. This controls the shift points/pressure in the 700R4. Without the cable hooked up, you're gonna have some problems.
Car: 86 Camaro
lol problem solved. i went with lokar kick down and throttle cables. lokar also makes a special bracket specificly for their kick down and throttle cables to adapt to TPI or carbed systems. VERY nice stuff if your willing to pay for it. nothing like polished stainless lines
Car: 86 Camaro
you can buy a brand new 700 built to take a beating for 800-1200 range. can handle 600+ HP and TQ. no point in getting your old one rebuilt for the money it costs
i bought mine from transmission.net they sell it and it's only $32.
I have switched to a turbo 350 and have my whole trans for sale including the lock-up from 700r-4.com and the proper throttle cable. My trans is a perfectly good working vette trans that has high mileage on it. I want $150 for all of it, but i will not ship it.
Mike
Anyone local to Sb , Indiana interseted ?
Mike
Originally posted by Charged350
any links for this bracket
Car: 86 Camaro
you can also buy the tv made ez kit from www.700r4.com its 125 bucks though
it's gone. I gave it to the local trans shop. I don't like stuff sitting around in the garage.
sorry
BTW it worked perfectly but had 135K miles on it, may have worked forever, may have broke tomorrow, that's why i put in a new turbo 350. Trans and converter cost the same as the rebuild on the 700
sorry
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
