Is It possible to mate a v6 T5 to a 305?
Old Mar 16, 2004 | 10:18 PM
proshoraca's Avatar
sorry for a seemingly stupid ??....but in a swap process and was wonderin if i could use my '87 T5 2.8Tranny with a '86 305 motor...thanks all
-Marshall
Old Mar 17, 2004 | 01:47 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
im not sure about that, i hear u can take a v8 T5 bellhousing and use it on a v6 T5, but then there might be the issue of spline count, clutch size
Old Mar 17, 2004 | 11:34 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yes, you need the V8 bellhousing and flywheel, the disc will either have to be an improperly sized one from an 84 V6, as they were avail 9 11/16 rather than 9 1/8 like the newer ones, or you can get one made in the stock V8 diameter, some of them have a longer stub on the input shaft where it goes into the pilot, which you may need to grind down, i've had both ones that worked fine, and one that I had to pull the trans just to fix the problem, so grind it first to be safe.
- Anyone replying after this post with a "no" or a "i dont think it will work" can come to tampa, bring $500 to bet, and we'll put my 92 Z28 on the lift here and see whats in there.
Old Mar 17, 2004 | 12:20 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
wooooh betting! nah, you can get it to fit, but for the time and money involed you can just find a nice used t-5 made for a v8. ive seen used t-5s with everything made to convert go for 300-500
Old Mar 17, 2004 | 04:08 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The betting is cause im tired of every idiot on the boards saying it cant work, and you'd be hard pressed to find a fully complete, working order WC T5 kit for 300-500, he'd be looking at a much smaller bill for the stuff to use his existing transmission.
Old Mar 17, 2004 | 04:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will fit, but I dont think the V6 version is anywere near as strong as the V8 version... and the V8 version isn't exactly bulletproof.
Old Mar 17, 2004 | 05:56 PM
Kontrax's Avatar
Car: 86 Camaro
if he did the work himself maybe hed have a smaller bill. BTW i never said it couldnt work. i agreed with you
Old Mar 17, 2004 | 06:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
When I said kit, i wasnt referring to installation, im talking about a complete setup down to all the bolts, not missing anything, or something broken being pawned off on some unsuspecting person.
Old Mar 17, 2004 | 10:26 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
The inside of the V6 T5 World Class is exactly the same as the V8 one. The only difference is the input shaft. I have interchanged V6 and V8 parts before and have had no problems. There is no difference. At least there's no difference between the 91 and 92 models.
Old Mar 17, 2004 | 10:33 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Several years I put a v8 in a 91 rs v6 5 speed car. We used a V8 bell housing V8 clutch diaphragm, bought a clutch disk for 86 S-10 blazer 4x4 does it work.. Hmm .. When my neighbor drives it home from work tonight I will ask him how it is.. That low fist gear is nice!!
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
ThUnDeR2005
Mar 22, 2005 01:15 PM
Dean-B4C6SPD
May 28, 2003 08:18 PM
