no reverse
Old Mar 17, 2004 | 07:49 AM
Dr. Suess's Avatar
Car: 1986 Chevy Camaro IROC-Z
no reverse
this morning i went out to my car and 1st, 2nd, 3rd, overdrive and neutral are forward gears and reverse is neutral and park is park i think that maby the cable needs to be ajusted. any ideas?
Old Mar 17, 2004 | 12:32 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
sounds like the shifter pin is out of place. very common for colum shifters, but havent see it on center console cars much. you need to pop the plate off, set the pin into park and set the cable up. so yes, adjust the cable
Old Mar 17, 2004 | 01:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Might also check to see is the pressure regulator is still in the case. A broken c-clip on the regulator or it slid down the bore a bit would cause you to loose reverse. Was this recently worked on? SK install maybe?
Old Mar 17, 2004 | 02:36 PM
Dr. Suess's Avatar
i was tryin to get outta my driveway when i noticed this problem and the transsmission has had no work done on it
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
nova983
European Region
Nov 2, 2015 12:15 PM
84redta
Sep 19, 2015 09:58 AM
