Speedo gear replacement
Transmission: 4L80E/4L80E
The driven gear is easy - remove cable, remove clamp bolt, pull gear housing, put new gear in housing & reverse disassembly. Some gears use a different housing than others, so you need to know which housing the gear you're going to use needs.
The drive gear is a little more involved. You need to remove the tailshaft housing, remove a clip, and slide the gear off the output shaft.
On a '66 TH400, it's even more complicated, because the drive gear is pressed onto the output shaft...
Car: 83 Z28 silver
Engine: 350 Reman
Transmission: bw T5 5-speed
thanks for the input, the manual i have did not cover the subject very clearly
ps: you are the only other person from colorado i have seen on these boards, do you ever go to bandimere?
https://www.thirdgen.org/techbb2/for...?s=&forumid=30
I do Bandimere in the Friday evening and Saturday ET classes, but in the '57.
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I'm on here quite a bit. Where are you from? I have been known to go to Second Creek, but this year I'm going to try to get up to Bandimere to get some hard numbers.
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes, I have done it all. Speedo gears on both manuals and autos with both a VSS and cable driven. Yours is cable obviously. On the T-5 it is easier if you take the tranny out. You have to remove the tail shaft of the ranny. You will be basically taking it apart in half and all the oil will come out when you do this. Then the little plastic gear is just on the output shaft held by a little metal clip. There is a metal ring around the end of the output shaft where the driveshft is, it is kind of hard to take off but it will come off. The easiest way to get both the ring and the gear off is to use a big open end wrench or an adjustable wrench against the sides of the gear then lightly tap on the wrench and "press" it off. The same to install it. Then just swap the little plastic gear that goes into the cable housing thing that the cable screws into.
Car: 83 Z28 silver
Engine: 350 Reman
thanks guys for the t-5 input I will need it soon when I get a new speedo and speedo gears. I guess I did not ask about what tranny it was for but originaly the question was for a th700r4 my friend has a 89 iroc and I was not sure if it would be the same as my tranny. But thanks for all the help guys
Ps: I live in Westminster/ Arvada area and have not got my Z to the track yet so I have no idea what I run in the 1/4 but want to get up there soon. also gta-spd do you live near dacono/ firestone?
Car: 94 Corvette
Engine: LT-1
... originaly the question was for a th700r4 ...
Add about 7.25% to the ET other people get with a car similar to yours as a baseline for what to expect the first time you take your car to Bandimere. It's that altitude thing.
beachrodder
Aug 7, 2015 04:27 PM
