Drivetrain LOCKUP! help!
Old Mar 21, 2004 | 08:14 AM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
I was driveing home last night and about a mile away from my house, when my car suddenly shuts off on a backroad. dead stop. right before it happened my warnings were all of a high pitch squeal comming from what seemed like my front left wheel or possibly under my hood only lasting seconds, then a nasty stench of a burnt odor, then no power, and i came quickly to a halt.
lights, radio, windows work, battery is fine
full oil, just changed a week ago, clear not burnt
full coolant not burnt
everything seems fine under the hood
the first thing i did was to check my oil but it was fine, because engine sieze was the firrst thing that came to mind!
when i turn the key, the engine cranks about 1/8th a revoulution, and you can hear something is obviously holding it back!
i have a new starter, just changed out a month ago.
what is going on!?
my tranny was about to go and was in desperate need of a rebuild, ( t-5 ), and i know it was low on fluid
but even in neutral my car still wont start.
HELP!
Old Mar 21, 2004 | 09:16 AM
CbraKlr88's Avatar
squeal...burnt odor...no worky..
check your belt(s), i mean you checked your oil but you may have overlooked the belts on the front of your engine.
thats my bet.
Old Mar 21, 2004 | 01:51 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
if the motor doesn't crank. take the serp belt, or the accesory betls completley off. and see if it'll crank/start.. if it does... find thelocked up pulley.... most likely an AC compressor, or the air pump. the rest of the pulleys are typically too small to lock a running engine up... although don't rule out the alternator.
Old Mar 21, 2004 | 02:42 PM
blk87ta's Avatar
Car: 86 Camaro Z28
Engine: LB9 305
Transmission: TCI 700R4
check your water pump, one of the impelers inside may have broken off and jammed up inside the pump
Old Mar 21, 2004 | 03:16 PM
Engine: 305 TBI
YES! Locked up altenator, faulty i guess, and I just replaced it 3000 miles ago, I had the warranty so i got a brand new one free. Put a new belt in too since the last one just got the hell burned out of it.
man i feel stupid for saying that its was my drivetrain but i had no idea what could've been going on and was kinda freaking out. also didnt think that an altenator pully could stop a V8, even with warm belts.
anyways, what a relief.
THANKS GUYS!
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
usafirebird
Oct 1, 2015 01:57 PM
Chevykid810
Sep 28, 2015 12:57 PM
usafirebird
Exterior Parts for Sale
Sep 21, 2015 01:23 PM
