t5 vs t56 master cylinder
Old Mar 24, 2004 | 01:33 AM
ehacker01's Avatar
does the t56 m/c reservoir line come out differently than the t5 m/c? I am having some clearance issues. also... can the t56 m/c hookup to the t5 slave cylinder line...and can the t56 m/c and braided line hookup to the t5 slave cylinder? I have posted a pic of the problem i am having.
Old Mar 24, 2004 | 09:51 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
They both come out at the front you shouldn't have any clearance problems unless you drilled the hole too close to the brake booster.
Here this is the T-5 one
Old Mar 24, 2004 | 10:16 PM
ehacker01's Avatar
yeah but this is in a malibu.
Old Apr 5, 2004 | 04:27 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t5 vs t56 master cylinder
No, the connections are different.
I don't remember the T56 res. line coming off any differently but I'm forgetting at this point.
The g-body is a pain in this regard. I've thought about a few things around this. Using a 91-96 b-body booster and a spacer might work; the pushrod has a .25"(?) offset, and is 1" longer or so.
A friend is running an f-body brake booster (bracket holds it away from the firewall.)
tap the master & do a 90 degree fitting.
So I've experimented with all of the above, and ended up adapting mechanical linkage to a 95 T56.
Old Apr 5, 2004 | 11:42 PM
ehacker01's Avatar
I ended up using a piece of 3/8 hard fuel line to run the res. line up along the brake booster to fix it. it seems to work so far. I also had to change to a later style monte booster...83 and up I believe.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
