need help with this t-56 and gear ratios
Old Mar 24, 2004 | 04:08 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i am looking at this 6 speed transmission t-56 out of the serial numbers i went on tremecs website and got the gear ratios here
here is the numbers on the trasmission tag so i guess its this model here are the numbers check to see if i am right 10236021 F1832 1386-007 E 14504
1386-000-007
weight129/58.6
torque 350/474
gross weight vehicle3,327/1,509
1st 2.97
2nd 2.07
3rd 1.43
4th 1.00
5th 0.8
6th 0.62
reverse3.28
ok now is this the gear ratio everyone says is for the 94 and up camaro i want to get the best gas mileage possible in 6th gear if so can ayone give me a list of model numbers for the best gas mileage....now i hear its .5 for the overddrive??? 6th gear right? here is where i got the information..... anyones help would be greatly appreciated
http://www.ttcautomotive.com/English...s/T-56.asp#Car
Old Mar 24, 2004 | 08:26 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
that is the 1993 t56.
the 94 and up has shallower gearing with the higher overdirvie of .50
Old Mar 24, 2004 | 10:16 AM
Drakar's Avatar
that one listed is also a G92 tranny as opposed to the standard one for 93.
http://www.f-body.org/tech/4th_gen.htm
half way down the page has the info your interested in.
also a note 93 trannys are usually cheaper then 94-97 as per the gearing and torque ratings are only to 400 in 93 and 450 in 94-97.
but as said above if you rlooking for best mileage ... 94-97 with .5 6th gears lets you run 4.10's no problem
Old Mar 24, 2004 | 12:48 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
would 500 be too much for this tranny??? can i install a .5 final gear ratio if i buy the new 6th gear?
Old Mar 24, 2004 | 02:03 PM
Drakar's Avatar
no clue on changing gears ........
as for it surviving behind 500 horse .... someone with experince would probably better to answer that.
Old Mar 24, 2004 | 02:26 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
lol i meant 500 dollars
Old Mar 24, 2004 | 03:15 PM
Drakar's Avatar
well I don't know about your area but 94-97 T-56's are usually between 2000-2500 CAN$ but 93 go for under 1K
so it depends, 500 bucks sounds like a good deal.
tonys91rs
Oct 10, 2015 03:31 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
