how to make an electric speedo to a cable speedo
Old Mar 25, 2004 | 03:18 PM
NEOMASTERZ28's Avatar
Car: 85 z28
my tranny recently died, so im gettin a good deal on another tranny from a 89 z but the only thing is that they have an elecric speedo hook up and my car is an 85 with the cable hook up.
is there a way to fix this , or do a swap, or can i leave it unpluged ??
thanks
Old Mar 25, 2004 | 03:45 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If they are both 700R4's then you just have to swap over the speedo gear from your old one and put in the correct gear housing that a cable can screw into from your old one. Go to www.700R4.com and look at their cable speeo packages if you need an idea of what needs to be swapped. I did the swap in my 89 RS.
Old Mar 25, 2004 | 06:28 PM
Car: 85 z28
i just need to swap from electrical connector to the cable screw on connector
Old Mar 26, 2004 | 01:11 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yup, that's all.
Remove the 10mm bolt next to the sending unit, and pull the unit out. Make sure the speedo drive gear inside the new trans is the same color as the one in the old trans. Put it back together and enjoy.
Pete
Old Mar 26, 2004 | 10:24 AM
GASGZLR's Avatar
You can phyically swap the VSS for the cable sleeve/housing but the VSS speedo gear WILL NOT work with the screw on housing for a cable. The cable driven gears come with a shaft molded into them which the cable goes into. I know cause I did the same thing I just swapped the VSS in a 90 trans to a cable driven housing with NO change to the rear end and the drive gears are te same but the driven ones were different even though they are the same color.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 7, 2015 04:27 PM
