T-5 into an 82 Z
Old Mar 26, 2004 | 06:01 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
T-5 into an 82 Z
My car is an 82' Z28 with a Th-350 in it right now. My motor is a 78' block. I found a complete 85 T/A parts car and want to swap the t-5 into mine. I should be able to just bolt everything in right. Will the 85 Flywheel work on my motor? It should be pretty straight foward right. When I asked about other tranny swaps before I was told I needed flywheels etc for an older motor. The 85 should be the right flywheel though? Thanks again
Old Mar 26, 2004 | 10:43 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes it should bolt up, they are both 2 piece rear main seal motors. As far everything else though, it will bolt right up. You got lucky that your parts car was a similar motor and speedo cable driven. I have heard stories of people having to swap over VSS's and speedo gears, and flywheels, and after they are done the only thing that actually came out of thier donor car was the T-5 itself,
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
