10 Bolt axle end play, what is normal?
Old Mar 25, 2004 | 08:42 PM
Fbody fan 35yrs's Avatar
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
When my 91 Camaro is on the jack, and I pull, and push in, and out on the rear wheel there is some play. What is concidered a normal amount of movement. It is a low milage car and play has always been there even right after getting it back from the drivetrain store with a new gear and set up. I know the C-clip on the end of the axle holds it all together. Is there a way to shim or adjust for the slop?
Old Mar 26, 2004 | 10:21 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
In and out movement is normal w/ c-clips, up and down movement = bad bearings
Old Mar 26, 2004 | 11:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I read somewhere (but have no experience) that the C-clips can be reversed/turned over to eliminate a bit of play.
JamesC
Old Mar 26, 2004 | 03:38 PM
ede's Avatar
ede
new c clips may reduce it soem. i'm thinking something like .050 is acceptable.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
