effect of Posi Rear End
Old Mar 26, 2004 | 03:00 AM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
How much of a difference in feeling/power does a posi rear end make?
is 250$ too much to pay for a 2.73 Iroc posi rear end?
How hard would it be to swap this with the stock 2.73 rear end?
Old Mar 26, 2004 | 04:04 AM
ede's Avatar
ede
if the gear ratio stays the same you won't feel much differance, less spinning since both tires will be digging in instead of one. it's a direct swap.
Old Mar 26, 2004 | 06:14 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
if there's one thing I learned from drivetrains its that 2.73 gearing absolutely SUCKS. it's one of the lowest gear ratios GM has ever produced. Posi won't really show much help when you're still turning the rear 2/3 the speed you'd like to be at!
Old Mar 26, 2004 | 07:23 AM
Bandit5's Avatar
It will help with traction off the line since you are using btoh tires instead of just one. If you are sending power to just one tire, it is more likely that it will break loose and spin... get it to both tires, and you can have much quicker accelleration thorugh better traction with both tires spinning.
Old Mar 26, 2004 | 11:37 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yeah I never noticed how much different an open rear is than a posi until I got used to driving my 90 with a zexel rear then went over to driving my 89 2.73 open rear TBI car. The 89 turns easier when doing a U-turn but when you pick up speed it feels real loose like the tires are going back and fourth sharing traction.
Old Mar 26, 2004 | 11:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: effect of Posi Rear End
in the last 2 weeks, ive swapped rears in my car 4 times....
gears make a huge diff... but the posi..
well it is un-noticable in a good way... let me explain..
say you're pulling out of a side street and you hit the gas... with a open diff you can very easily spin the one tire.... or atleast feel it slip a bit... annoying...
with the posi, you dont have that problem... both tires do the work, and the car just glides smoothly away.
i noticed no diff in low speed turning either... but when im banging thru the gears at the strip, the car goes straight.. none of that tweek to the side for a second stuff.....
now, its been warm and sunny for the most part these last two weeks... i havent driven it with a posi in the rain yet... but from your username, i'll assume you dont get much rain either...
Old Mar 26, 2004 | 05:27 PM
91RSHawaii's Avatar
hehe thanks guys, i think ill wait it out till i get a chance to bag a higher ration posi trac rear end.
what would the best ratio be for a total stock 91 rs lo3 though?
Old Mar 26, 2004 | 07:00 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
ratio depends on what you want... 273 is cruising/gas milage gearing, 323 is 1 on a scale of 1-4 level performance/good gas milage gearing, 342 is 2 level performance/ ok gas milage, 373 is 3 on performance (very desirable gear ratio probably the most popular)/ ok gas milage... people debate about 373 and 342 being the best all depends what you want... you could even go 411 on the ratio which is all out performance f' the gas milage
IMO 373 is the gearing to get... 342 is more abundant but you can also buy a posi unit and put gears in it yourself just make sure you get the right spline count
I went from a 90 Formula with 323 to 373 and loved the difference it takes off like a bat out of hell off the line compared to 323.... i now have a 91 RS with an open rear and i dont mind it but need posi b/c of the traction issues... in an open rear one tire gets power making the power distribution uneven... in a posi both tires will spin when loaded and you will get even distribution of power which means more traction and better 60' times(acceleration increase)
Old Mar 27, 2004 | 09:44 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i run 4.11's and it pulls real good but i am lucky to get 16 mpg
Old Apr 28, 2004 | 07:20 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I have 3.42's and it's a posi, too. It gets okay mileage but it pulls nice and healthy, too. Depends. You paying gas out of your own pocket, and with the prices here in Hawaii being what they are, I sort of envy you for the gears you got.... nah, I'll keep mine anyway.
Old Apr 28, 2004 | 07:52 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
mine's limited slip 3.23 and it's terrible in the rain. if i even touch the gas it slides the *** end around everywhere. but it is nice to have it grip from both sides and it does shoot farrely straight down the 1/4 mile
Old Apr 28, 2004 | 08:45 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
need I say anything?
Old Apr 28, 2004 | 09:18 PM
Engine: 450HP 355
Transmission: TH350
HAHA
Old Apr 29, 2004 | 12:09 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I have 4.11's in mine. You can be going 25mph, floor it & light both tires up. Care must exercised that you don't do a 180. Posi's can cause this especially on wet roads.
Old Apr 30, 2004 | 10:51 AM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Yes, 2.73's definitely suck. But imagine having the 2.59 gears that are in the vette rear ends!!!
Old Apr 30, 2004 | 11:18 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah man if you have the knowledge and $$$$ go and buy a aftermarket set of gears and do it yourself you will get more for your money .....
Old Apr 30, 2004 | 01:49 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
Don't 323s and up really suck for traction? I have the 2.73 posi and cant stop spinning tires now. Or is that the point?
Old May 1, 2004 | 08:36 AM
Engine: 450HP 355
Transmission: TH350
on dry asphault i can barrely break em loose with my tranny/rear combo (TH400/3.23 LSD). but i also have 275.60.15's on the back....
Old May 1, 2004 | 12:07 PM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
Aren't all posi's limited slip? I'm pretty sure they are.
Old May 2, 2004 | 01:26 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I know well what a 'one legged wonder' is like... I have a 3.73 rear and no posi... to make a long story short, one tire has alot less tread than the other... about 1/8" difference. (yes, I am getting new rubber soon)
I'd kill to have a posi.
Old May 2, 2004 | 01:42 AM
Engine: hamsters
dont say that, id trade my posi (2.73's) for 3.73s anyday
Old Jun 2, 2005 | 09:08 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
the 89 may turn easier doing a u turn but i'd rather have a posi for V turns lol
Old Jun 2, 2005 | 11:31 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Posi's (positive traction full name) is GM's name for Limited slip differentials.
Well depends on the brakes partially, if they are PBR's then the rear is worth more money.
Swaping would be direct, (no speedo gear changes, no brake line changes) maybe a proportial valve if you change brakes.
Old Jun 3, 2005 | 08:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
technicly, its fullname is "Positraction".... thats the GM marketing name for a limited slip diff......
of course, now all limited slips are Posis... who knew marking names would apply to more then the orignal product?? now excuse me while i windex the xerox machine with a kleenex.......
Old Jun 3, 2005 | 09:25 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Hope 91RS has made a decision by now, that was over a year ago guys.
Old Jun 3, 2005 | 09:50 AM
Car: 91 Camaro RS
Me too
Old Jun 3, 2005 | 10:01 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
perhaps he works slow?
id be lazy if i was in hawaii...... lol
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
