What speedo gear will i need to use
Old Mar 26, 2004 | 08:32 AM
l98irocz's Avatar
Well i just bought a rear disk rear end out of a 88 iroc. it has a 3.45 borg warner gear ratio. it came out of a manual car, and I have a 700r4. I need to know what speedo gear i need, like the color and the # of teeth... i went to this site
http://tciauto.com/tech_info/speedo_gears.htm
but did not understand it.... thanks in advance
Old Mar 26, 2004 | 08:44 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have both gears that I pulled out of my 700R4 with 3.42 rear. They are a gray drive 15 teeth, and yellow 41 teeth.
For a cable driven speedo you need:
GRAY 8642620
YELLOW 1362195
For a VSS you need:
YELLOW 25513048
same gray one
BTW; I have both gears and the VSS(electronic) to go with it if you are interested PM me.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
