clutch set-up
Old Mar 26, 2004 | 10:22 AM
jrm's Avatar
jrm
clutch set-up
I am in the process of putting a t-5 out of an 88 iroc into my 82 Z. I have the tranny, clutch, bellhousing, fork, drive shaft, torque arm, and shifter. Now all I need is the clutch pedal assembly. My question is, I know the t-5's came with hydraulic clutches, but can I use a mechanical clutch set up? I can get linkages/pedals out of an 82 4 speed car for free, so thats why I am asking.
Old Mar 26, 2004 | 10:37 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I don't belive that the Z bar linkage will work with a Hydraulic T-5 setup but the actual pedals might be similar, you still need to get the master cylinder and slave cylinder setup and install it on the firewall. The actual pedals might be the same, but instead of mechanical rods hooking to the pedals, the slave prolly just connects tro the same place, but I am not too sure, just PM me if you are still confused.
Old Mar 27, 2004 | 12:42 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The clutch pedals are different, the bellhousings are different, and the clutch forks are different between the hydraulic and mechanical setups.
And to further confuse the issue, the only year of mechanical bellhousing that will work with a T5 is 1983. Only 1983, meaning they are hard to find.
The hydraulic assembly can be installed into your 82 with minimal modification; basically just drilling a couple of well-placed holes in the firewall.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
