auto to a 6 speed....is it hard?
Old Mar 22, 2004 | 07:10 PM
dirt's Avatar
Car: 1987 RED RS
Engine: 2.8l
Transmission: auto
My red RS is ready to fly, and she is asking for a 350 engine, and my question is it hard to make a AUTO 4 speed to a 6 speed t56 trany or how about a 700r4 tranny?
I switch tranmissions before but never play with manual tranmission or clutches.
Old Mar 23, 2004 | 09:46 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
harder than switching out autos with other autos.....but not too bad, no. if you're fairly handy with tools, and had a day or two, you could do it. fbody motorsports has an awesome article on it, and they sell a crossmember to fit the t-56. I would use Spohn's crossmember, because it moves the torque arme off the tranny, and allows you to have a driveshaft loop all in one package. also, read the sticky at the top of this forum, and then do a search on here. this question and the ones that follow have been answered before, so you should find a wealth of info at your disposal.
the main thing to remember is to get as much as you can from the donor car. and look for a tranny from a 93-97 f-body. L8r man.
Old Mar 23, 2004 | 11:31 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i have a 700r4 and its not bad if adjusted properly but nothing beats shifting. try reading thru this http://www.skulte.com/T56.html
Old Mar 23, 2004 | 05:19 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I found nothing about the swap overtly difficult. Basically it is a bolt in that requires a few specialized parts. Skulte's article is the best one I saw on the web concerning the swap. I used his crossmember too. It fit like a glove.
Old Mar 23, 2004 | 07:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not hard at all.
takes a lil time, but its not hard at all... it all bolted together quite smoothly.
Old Mar 23, 2004 | 10:25 PM
dirt's Avatar
Car: 1987 RED RS
Engine: 2.8l
Transmission: auto
Ok, if it's easy and a lot of time....I'll do it to save money. DO you guys know a 350 put aleast 310hp to the ground for cheap...I was thinking of a LS1? But it's cost too much for a little old me.
Old Mar 24, 2004 | 04:34 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
whats ur price range
Old Mar 24, 2004 | 05:26 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Do you want fuel injected or carbed? I have very little money in my motor. Just a regular old 4 bolt main truck block with heads intake and cam and exhuast. Dynoed @ 316 hp and 385 ft/lb of torque. Plus a better cam and some nice heads are in its future.
Old Mar 24, 2004 | 01:31 PM
dirt's Avatar
Car: 1987 RED RS
Engine: 2.8l
Transmission: auto
Oh, hmm.....my price range is under 2G's. I was thinking pull it out of my 70 truck,.....The engine doesn't sounds too good, but i guess i can rebuild it...What cam should i add?
Old Mar 24, 2004 | 04:07 PM
Goodwrench 350 shortblock with Vortec heads and a 268 Extreem Energy cam. You'll have to go carb, unless you already have EFI (even then you need a special lower intake that is $400 by itself to work with the Vortecs). For a carb motor this is a great combo that can be done for about $2,000 if you reuse all you old stuff like oil pan, timing cover, ect.
Another option if you have EFI would be to use a Goodwrench crate motor long block. The EFI should bolt right up, unless you've got a post '87 intake. I'd mill the heads or use a steel shim head gasket to get some compression back, and use the same Comp Cams cam mentioned above.
Old Mar 25, 2004 | 10:55 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
for 2k you can get a mild GM350 crate. youll need to get an intake, distrubter and carb if u dont have ones thatll fit... look in summit they have all kinds of great things
Old Mar 26, 2004 | 05:39 PM
dirt's Avatar
Car: 1987 RED RS
Engine: 2.8l
Transmission: auto
I can't find a single engine you guys told me.....Anybody has links?
Old Mar 27, 2004 | 04:51 AM
Summit Racing is selling GM crate motors. Go to www.summitracing.com
Scogin Dickey is another great source. Not 100 % sure of the website.
BTW, you can get a GM 350 crate long block rated at 330HP for $2,300. Might be a better starting place than the Goodwrench.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Breazlan
Sep 25, 2015 11:20 AM
88rscamar0
Sep 23, 2015 09:08 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
