Tranny Break-in
Old Mar 28, 2004 | 10:25 AM
cargasm66's Avatar
Car: 89 RS
Engine: 305 TBI
Tranny Break-in
The '91 Z28 that I'm buying today has a freshly rebuilt 700R4. The old owner says that there's about 120 miles on the rebuild. Is there any kind of break-in process that I need to go through? Should I change out the fluid? I suppose it means I have to take it easy on the gas once I get it, no stoplight racing How long do i have to behave??
Thanks!
~Chris
Old Mar 28, 2004 | 08:29 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You should be able to drive it however you want at this point. You may want to change the fluid out in a few more miles just to make sure there's no crap in it from the rebuild. Maybe at 500 miles or so.
Old Mar 29, 2004 | 08:33 AM
cargasm66's Avatar
Car: 89 RS
Engine: 305 TBI
Thanks!
As I was driving it home, I noticed it was shifting REALLY early. Steady Pedal, I was in 4th by about 30 MPH. The tach doesn't work, but it felt like it shifted into 2nd at about 2500 RPM or less. Is this a normal thing? Is there a vac advance that I need to adjust or anything?
Old Mar 29, 2004 | 11:47 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Check the TV cable adjustment...
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
