TCC lockup switch - I read the tech article
Old Mar 29, 2004 | 02:27 PM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
I read the tech article about wiring a manual switch to control whether the TCC will be controlled by the computer vs. not locked up at all. Anyway, it cautioned that installing/using the switch is hard on the tranny and torque converter. I just want to check that the harm is actually when you leave the switch in a status where the TCC is not locking up, when you're cruising on the freeway. The tranny and torque converter will heat up a lot faster and it's probably dangerous to drive long distances. If this is the case, I understand this.
Will just using the switch or installing it (permanently) cause harm? I know that excessive use of the switch so the tcc is constantly locking/unlocking is bad also. I only plan on using it when going onto freeways so it doesn't lockup until I get up to a certain speed. I don't see how using the switch and/or installing it might cause harm to my drivetrain... Can anyone clarify?
Old Mar 29, 2004 | 04:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TCC is a tiny little thing that was designed to be locked up when maintaining speed. WOT acceleration with it locked up will probably burn it up much faster than a few locking/unlocking cycles.
Old Mar 29, 2004 | 04:42 PM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Oh yeah, one more question. I bought and installed the TCI-lock-up delay harness already. It has helped but only a little. My tcc still locks up before I want it to while accelerating onto freeways. Is there a way to modify this delay harness to have it delay it even longer? Or should I just go ahead and install a switch.
Any help you guys can provide would be great.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Thirdgen89GTA
Aug 25, 2015 06:40 PM
355sbcTPI
Aug 19, 2015 04:38 PM
