just changed fluid, now leaking
Old Apr 3, 2004 | 05:11 PM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I just changed my tranny fluid and filter, put a new gasket on and sealant. Filled the tranny and I look under my car, it is leaking, slow drip in the back on the crossmember. Could I have done something wrong? Overfill? I really dont want to start all over again. Its such a hassle.
Old Apr 4, 2004 | 10:22 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The most likely culprit is a leaking pan gasket. They can be a pain to get to seal right. If you made it to tight or not tight enuf it can leak.
Old Apr 4, 2004 | 10:47 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
So I may have overtightened it, Should I just loosen the bolts up and go in a diagonal pattern and not tighten them up as much, or will I have to get a new gasket? Also my gasket sealant says that it takes 3 hours to dry, I suppose I got the wrong kind?
Old Apr 4, 2004 | 10:57 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Old Apr 5, 2004 | 08:46 AM
dankhound's Avatar
Car: 91 RS
Sometimes when you overtighten youll rip the gasket. What kind of gasket was it?
Old Apr 5, 2004 | 11:08 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
It was a rubber gasket, I may have used too much sealant on some parts and it didnt sit right. I'm going to get another gasket and do it again. Napa carries the cork/ rubber combo, at least thats what the guy said on the phone. Should I use sealant again?
Old Apr 5, 2004 | 11:01 PM
dankhound's Avatar
Car: 91 RS
I used the rubber gasket from napa. I put it on dry and havnt had any problems with it leaking. Ive found its easier to put bolts in a little on the loose side and then tighten them up some if you see any leaks. Of course ideally you should use a torque wrench but after awhile you get a feel for it.
Old Apr 6, 2004 | 09:16 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
appreciate it
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
Thornburg
Aug 25, 2015 01:46 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
