3.73 gear id markings and measurment?
Old Apr 4, 2004 | 05:21 PM
Z-Monkey's Avatar
Car: 83 Brlntta in Z28 clothing
Engine: 305 LB9 POS until 350....
Transmission: hurting 5 spd- Crunchy...
I bought what was labeled as a 3.73 gear set at a swap meet today, mainly 'cause it was cheap as hell and I'm impulsive, but now I'm doubting that it's a 10 bolt 3.73 set-up. The ring gear has "373" "YLDA" "02-45" and a "V" There are 12 holes in the back. The pinion gear has "273" "3W7" "CA" "M" "3N" (underlined) and a "V". What the hell do I have here? If I were to measure them, what would I use? overall? the interior hole? Any help (or pictures of the real thing) would be appreciated.
Z
Old Apr 4, 2004 | 08:19 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Count the teeth. Count the # of ring gear teeth, and divide that by the # of teeth on the pinion. I did an install on a set of 3.73s yesterday, and it was 41 ring gear/11 pinion gear teeth which is 3.727 or 3.73...
Old Apr 4, 2004 | 09:25 PM
Z-Monkey's Avatar
It's 41/15, or 2.73. But it just doesn't look right, the pinion head seems much larger than it should be. I think I may have mis-matched pieces, they don't seem to mesh the way they should. How can I tell the size of the ring gear? What should I measure? It's in perfect shape, and if I can use it I'll just order a 11 tooth pinion gear-
Z
Old Apr 4, 2004 | 10:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can't use a 2.73 ring with a 3.73 pinion; there's more differences than just the number of teeth. The thickness, for instance.
10-bolt ring gears have ..... 10 bolts. If you have a ring gear with 12 bolts, it's ..... (get ready for a surprise!!!) a 12-bolt one.
Sounds like you have a bunch of garbage. Basically, you got scammed; unloaded a steaming useless pile of crap on an unsuspecting victim.
Old Apr 4, 2004 | 10:32 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Sounds like RB is right. Looks like you will have to get a new SET of gears. Gears come in sets for a reason, b/c they are matched at the factory w/ each other, so getting a new pinion, or a new ring gear to go w/ what you have will not be a good idea.
Old Apr 5, 2004 | 06:52 PM
Z-Monkey's Avatar
Ah-crappity-crap-crap. This is basically what I had figgered out already, but I was hoping for someone to pipe up and tell me I got a great deal. I guess this sort of explains why the guy was so adamant about ripping the tags off it before handing it to me, and why, when I asked him about it, he said it was a friends and he was selling it for him. hey, a $30.00 learning experiance isn't all that bad. Now I gots me some nice paperweights. crap.
Z
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
BAMiller
Sep 14, 2015 06:38 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
