Front u-joint for 4th gen aluminum DS
Old Apr 7, 2004 | 06:17 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
No luck in searching. I have a 2001 Z28 driveshaft that I'm going to be putting in my 92 GTA. I got the Brute Force u-joints. The rear fit but the front is too big for the yoke. From my searches here some say the front is the same as the rear and others say that you need the front joint for a steel shaft and the rear joint for the aluminum shaft. Interestingly enough Advance Auto has the same part number for both.
Unfortunately the u-joint doesn't fit the front trans yoke. Does anyone have a part number or can tell me what exactly I need to get in order to fit this DS into the car?
Old Apr 7, 2004 | 07:33 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Remove the front one. Take it to a driveline shoppe. "I need one of these."
Works every time. Having others research parts for you that you hold in hand will have a much lower level of accuracy than you researching it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
