Delayed shifting problem
Old Apr 13, 2004 | 12:46 AM
dieseldennis's Avatar
Car: 1987 Camaro Z28
Engine: 5.7 HO TPI
Hi
I have a problem. I recently had to adjust my tv cable and now I am experiencing delayed shifts. she will shift only at around 3500 to 4000 rpms and this just normal city type of driving. Also she wont upshift at a city speed cruise even when I let go of the pedal.
Any Help????
Dennis
Old Apr 14, 2004 | 08:35 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
Ok...if this is what I think it is, the TV cable is attached to the throttle body, correct? If you did what I did, which was throw this out of adjustment, your transmission will not shift until a really high rpm...same thing happened to me. I just adjusted it back to its original position (there should be a little ratcheting mechanism inside its housing) and my trans was back to normal. It may require some trial and error though.
Old Apr 14, 2004 | 08:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello dennis,
Did you read the last post I made to your previous post on this subject.
https://www.thirdgen.org/techbb2/sho...hreadid=234918
Old Apr 14, 2004 | 10:41 PM
Engine: 5.7 HO TPI
Originally posted by Trickster
Hello dennis,
Yes I did read it....But my problem was that When I followed the directions you gave me I didnt understand that I had to adjust it by trial and error. I got it fixxed now though I think Thanks for all the help guys:rockon:
Dennis
Old Apr 15, 2004 | 08:20 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
I really should figure out how to adjust this cable on my TBI motor. I was experiencing very little downshifting, if at all before I winterized it. I took off my aircleaner right before I put it away but I couldn't figure out how to adjust it.
Does anyone have a diagram of a TBI motor?
Yeah I know... go ahead and call me a newb
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
overdriv
Aug 20, 2015 03:52 PM
dhonda200
Aug 11, 2015 11:50 PM
