Posi or not?
Old Apr 16, 2004 | 12:39 AM
daddy33's Avatar
Car: '85 Camaro
Posi or not?
hey guys, about 6 months ago i bought a posi unit from some guy on ebay. I think it was some factory GM unit but not too sure. When i put it in and when the car was on jacks i spun the tires to see if both would spin the same way. They didnt, one forward the other opposite. I was told if its posi they both go forward. But then when i do a brakestand both tires lite up! Then again from a dead stop when i punch it, 50% of the time only one tire spins, especially around turns.
No what does this mean? I have to have posi because i can spin both doing a burnout but then why does this other stuff happen? I want both tires to spin ALL THE TIME! I mean from burnouts, WOT off the line, around turns, etc.. Is there something i need to get or am i better off finding another posi unit?
Old Apr 16, 2004 | 05:50 AM
ede's Avatar
ede
you don't know a posi when you see one? that's usually the best and only way to tell for sure. the tire spinning direction, 2 tire mark method doesn't tell you much. most likely i'd guess you have a posi that doesn't work all the time.
Old Apr 16, 2004 | 07:20 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
the POSI is probably slowly going bad. just loke ede said, open the differential and see for yourself
Old Apr 16, 2004 | 08:57 AM
daddy33's Avatar
Car: '85 Camaro
im really not to familiar with posi units. If i take off the diff cover how do i tell if it is or not posi?
Old Apr 16, 2004 | 09:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=216268
Old Apr 16, 2004 | 04:01 PM
daddy33's Avatar
Car: '85 Camaro
so basically when my car is in the air and when only 1 tire spins one way and the other tire the other way its not posi?
Old Apr 16, 2004 | 04:19 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
Spool it
If you want both tires spinning all the time (100%) buy a spool. A spool locks both axles together the ring gear is bolted to it. They are in summit or jegs catalog, there are no clutches springs etc. But beware you can break stuff ( axles, u-joints, etc) with it and driveablity needs getting used to also.
Old Apr 16, 2004 | 04:45 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yes, much harder to do sharp turns on a spool.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
