Symptoms and question?
Old Apr 17, 2004 | 05:01 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Hey guys. Well i think my throw out bearing is on its way out, but not even sure because the noise goes away and only happens at a stop, so not sure. But what are some symptoms of one going and will this hurt anything driving with one going bad? Thanks
Old Apr 17, 2004 | 05:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Typical throwout bearing problem is that it makes noise when you push the clutch, but shuts up (at least mostly) when you let the clutch up. With the car moving or not.
A noise that occurs when the car is in neutral but the clutch pedal is up, is usually transmission bearings; since under those conditions, most of the guts of the trans are spinning.
I can't tell from your description which thing you have going on.
Old Apr 18, 2004 | 08:54 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah its the throwout bearing. Will this hurt the car if i drive it like this for a while. Money is tight.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
