.059" Pinion Shim!?!?!
Old Apr 17, 2004 | 09:37 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am in the middle of setting up a Moser 12 bolt with Richmond 3.73's.Pinion checking depth is 2.828 as per Richmond specs on the pinion.When I get the pinion to set at this depth of 2.828 I have a total of 4 shims on it totalling .059"?!?I have set up factory rears (10/12 bolts) with factory or Richmond gears and usually never need more than a .035" shim...one rear needed a .037"..that was the biggest I have used till this?!I am just curious if anyone has ever ran into such a large pinion shim requirement?Not really worried about it till I see what gear pattern is..and if it is good and that is what the gears require to set it up with a .059" shim stack so be it...more of a curiousity concern.
Old Apr 18, 2004 | 06:08 AM
ede's Avatar
ede
no 12 bolt, or any rear that i can think of i've done ever took that much shim.
Old Apr 18, 2004 | 02:40 PM
Zac's92's Avatar
I rebuild axles all the time at my work, that doesn't seem abnormal. Dwayne88IROC's 9bolt took a .094 shim to get a good pattern. It's just all the inconsistencies in the machining of the housings. If the pattern looks good it's fine.
Zac
Old Apr 19, 2004 | 12:47 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Thanks for the replies..like I said I have built only factory cased rears (8 total) up till this Moser unit (9th to date)..so it could be the Moser unit is manufactured differently..i.e different dimensions.I will wait to see what gear pattern reveals before I start the process over..like I said pinion depth is on spec as per Richmond..so we will see.I will post back when the results are found.
Old Jun 12, 2004 | 03:32 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am finally setting up the gears..pics on this thread of gear pattern.What do you think???
https://www.thirdgen.org/techbb2/sho...hreadid=245515
Old Jun 12, 2004 | 06:14 PM
89ROC's Avatar
I do this type of work for a living. The pinion shim shouldn't be more than .050. I've set up several Moser 12-bolts which usually require .30 on the average
6speedIROC
16
Mar 15, 2023 08:33 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
dimented24x7
Sep 17, 2015 06:58 AM
