Is my car leaking oil??
Old Apr 17, 2004 | 11:43 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
When i went underneath the car today i noticed lots of diff fluid splashed all above the rear of driveshaft and on the exhaust pipe.
I couldn't tell where it is coming from. The seal looks little wet but it is not too bad and the plastic relief valve is place..
Need help..
Old Apr 18, 2004 | 03:09 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
are you sure its diff oil? it may be motor oil coming from the front of the car...did you look all over the underside?
Old Apr 18, 2004 | 03:26 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
It smells like diff oil and it is so close to where the diff seal is.
That is the only place where there are any leaks.
If it is a diff seal would it be something i can attempt to do? I do have some mechanical experience but not much...
(I changed the clutch ones!!!!)
Old Apr 18, 2004 | 03:52 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
<b>Is my car leaking oil?? </b>
Yes. All chevrolets leak, discharge, disclose, divulge, drip, drool, exude, give away, let slip, make public, ooze, out, pass on, percolate, reveal, spill, transpire, trickle oil from somewhere.
whether thats whats in the pic or not is up for debate.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
gwade12
Aug 8, 2015 08:17 AM
drathaar907
Aug 6, 2015 04:20 PM
