chevy truck trans ?'s
Old Apr 20, 2004 | 08:08 AM
smoove2022's Avatar
Anyone know if a T-5 or a 700r4 from a thirdgen will fit in a 93 chevy 1/2 ton 2wd truck with a 4.3 v6? I've got a truck with a bad transmission (getrag 5 speed) and I just want to get this thing running. I know these trucks were available with a 4L60E and I've got a good 700r4. Are these tranny's interchangeable? I'd probably need an auto computer and a trans cooler if I swapped from manual to auto but it may be the cheapest quickest solution for me. Any ideas?
Old Apr 21, 2004 | 01:13 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: chevy truck trans ?'s
A 700R4 would work you would only have to change the gear selector peice from cable to linkage if you used a stock coulmb shift type B&M or any other AM peices would be cable.
If you tried to swap in a T5 the shifter would sit too far under the dash to be useable.
Old Apr 21, 2004 | 03:27 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The 700R4 would be your best bet. You won't need a computer with that trans. The only thing the ECM controls is the TCC & that can be gotten around with an aftermarket control kit.
jhawkeye
May 25, 2022 06:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
nuggie
Aug 25, 2015 01:27 PM
Kaweh
Aug 19, 2015 07:06 PM
