Trans rebuilt and acting funny..
Old Apr 20, 2004 | 10:28 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I got my trans rebuilt because it was getting stuck in 3rd and 4th real bad and grinding. So I get it back yesterday and put it in after work. I take it out today and everything is awsome. it shifts amazing and everything is just great. Then tonight coming home I leave my buddies house and I put it in 4th and guess what, It gets stuck. So i pull over cause nothign was getting it out. Then I ride the **** out of my clutch and get to a 711 that was liek 300 feet away. My freind pulls in and he jumps in and pushes and it comes out then all is fine, so i take off and bam stuck in 2nd then i get it out but nuetral is real notchy back and forth so i reverse it back to 711 and then i try for home again and its fine all the way home. Now what do you think this was guys?? He changed all t he syncros, blockers and 2nd gear, also he changed the gear with the straight cut gears on it. I really can't afford to go without my car again and I don't feel like pullin it so what do you think the problem is?? Its a T-5 if you didn't know. thanks guys
Old Apr 21, 2004 | 09:55 PM
Car: 89 Formula
Engine: Carbed 5.7
Come on guys some1 gotta know, Well anyways i drove it all today and it only did it once and it gets stuck in 4th only. I thought maybe it was my shifter so i changed it out wil a stock one and it did it again after that so I guess since its got all new syncros the 4th gear needs to be replaced right??
Old Apr 21, 2004 | 10:13 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Something must be hangin up in there. Did you get a warantee? I would take it back to the guy if thats the case or crack the case open and check it yourself. Is the clutch in working order and all?
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
KO1
Aug 31, 2015 06:31 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
