B&M change-over kit is kicking my ***
Old Apr 25, 2004 | 04:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Ok, I got the kit, its bolted on to the tailhousing. Took apart the TA bushing assembly off the 700R4, its in two pieces. How do they go together? I have no idea and the instructions arent helping me..
thanks guys
Old Apr 25, 2004 | 09:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
there should be a slot in one piece and a tab on the other. slide that tab into the slot on the other one. you might having to do some finageling to get it to go in. then screw it together with the supplied bolt. mine went in fine. that is how i remember it but i can recall off hand.
Old Apr 26, 2004 | 09:15 AM
So where does the piece with the long stud go? There doesnt seem to be room for it...
Old Apr 26, 2004 | 08:55 PM
ttt
Old Apr 26, 2004 | 09:40 PM
Nordbert's Avatar
I've never seen the B&M unit, but I removed the bushing half
from the plate with the long bolt and bolted it to the bracket I made. Can someone post pics of the B&M bracket or scan and post the B&M instructions?
Old Apr 26, 2004 | 10:36 PM
thats what im missing i guess, removing the bushing from the larger plates???
http://www.bmracing.com/products/kit...ngeoverKit.jpg
Old Apr 26, 2004 | 11:19 PM
Cuno's Avatar
The piece with the long stud does not get used...or if it does the long stud does not connect to anything...it has been a while since I did the swap...I will look tomorrow and let you know for sure.
Old Apr 27, 2004 | 09:47 AM
thanks man
junior419
Apr 7, 2025 11:35 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
L0tuS
Oct 4, 2015 08:07 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
