TV cable difference?? Is there
Old Apr 25, 2004 | 09:50 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
I have swapped to a TH350 after destroying 3 700R4's. I had a TV cable just installed but not hooked to my carb, but i'm switching to a HSR and want to know if i can just get any old TV cable and install it into my TH350? My old cable is busted near the tranny and leaking everywhere! I didn't hook it up before because i pretty much will manually shift it down if i need to school a fool. TIA
Old Apr 27, 2004 | 09:50 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Your kidding me right!!! NO ONE in here has ever had any dealings with their TV cable???
Old Jul 19, 2004 | 02:17 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Ok peoples i have my motor together and my HSR installed, now i'm coming down to crunch time and i still have never had anyone answer this question. Will a TV cable from a 700r4 trans work with a TH350? If i find a TPI car with an auto will that TV cable still work? I need the TPI length to run to my HSR. TIA
Old Jul 19, 2004 | 03:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 700R4 and TH350 TV cables are different.
Old Jul 19, 2004 | 04:30 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
The 700R4 TV cable controls the transmission line pressure.
The 350 cable control cable is a shiftdown or kickdown actuator.
If the 700R4 cable isn't adjusted correctly the transmission will fail.
The 350 won''t be hurt but you WILL miss having the 'kickdown' feature working.
Don't even try to run a 700R4 without a TV (THROTTLE VALVE) cable connected,adjusted and working right.
There's nothing special about the cables. Just difderent usage on the two transmissions.
Old Jul 19, 2004 | 08:24 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Thanks alot guys
TheTraut88
Sep 11, 2015 05:16 AM
64goatman
Sep 9, 2015 01:09 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
