how bad is this killing performance?
Old Apr 26, 2004 | 08:31 PM
no_car_yet's Avatar
the previous owner of my camaro, swapped from a v6 5-speed to a v8 auto. he got the engine from a blazer(305 4bbl) and it seems that he also put the blazer tranny in the camaro.
its a 3 speed (i am pretty sure)and the gears are really wide.
how much is this slowing the car down from say a 700r4?
i have started searching for a T5, and since the previous owner left the clutch pedal and manual shifter console and boot in the car, i figure it should be a relatively easy swap to a standard?
it doesn't seem like the blazer trans fit the camaro very good either, because i can hear a humming on the highway coming from the tranny. also their is no auto shifter hooked up to it, and the way i change gears is by push/pulling the shifter cable through the ash tray with a set of vice grips....needless to say, a sloppy job was done on the swap.
here a pic of my automatics interior for your amusment...
Old Apr 26, 2004 | 08:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
There's not a huge difference between a cars 1/4 mile time with a 700-R4 or a TH400 for example. You have a short first gear with a 700, but the % rpm drop from 1-2 and 2-3 is greater in a 700 than another tranny, so you gain one thing and lose another. I'd rather have 200-4R ratios than 700-R4 ratios myself.
Nice steering wheel.
Yeah, I'd swap back to manual.
Old Apr 26, 2004 | 08:52 PM
no_car_yet's Avatar
yeah i think the steering wheel looks alot better than the camaro one.
so this car would run pretty much the same 1/4 mile as if it had a 700r4? but the t5(assuming i can drive it good) should be quicker?
i was watching popular hotroding TV today, and the guys had a muncie, a t56, and a t5 laid on the table. the t5 never had a bellhousing but just the transmission part of it seemed to be much smaller than the transmission part of the muncie/t56...how much lighter is the t5 than a 700r4 roughly?
Old Apr 26, 2004 | 09:35 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
100 lbs i believe
NORTz89
May 20, 2020 03:51 PM
Reddeath210
Oct 6, 2015 08:20 AM
GTAman
Sep 21, 2015 09:57 AM
InfinityShade
Sep 5, 2015 06:38 PM
InfinityShade
Aug 22, 2015 08:00 PM
