just recieved corvette servo
Old Apr 26, 2004 | 08:35 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
hey, i just recieved a corvette servo, i havn't put it in yet though...i was wondering..when i installed my b&m shift improver kit, i think i remember they gave me a couple of spacers used to block off the accumulator pistons, which i used. i remember reading somewhere that it is not a good idea to run the vette servo with blocked off accumulator pistons. "they don't go well together" if this is true, should i order a new set of accumulator pistons and springs? i found the 1-2 accumulator piston and spring for 8.99, and the 3-4 accum. piston and spring for the same price on ebay made by monster transmissions. would this be neccessary? thanks
Old Apr 27, 2004 | 12:59 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: just recieved corvette servo
In an automatic trans, the manufactuer worrys about two things, Shift quality and shift timing. Blocking off the accumlators just makes the the clutches come on faster and harder by not letting the accumlator fill up.The vette servo also quickens up shifts by appling the band faster with a different sized servo piston.
I dont see any reason they cant be used in conjunction....One is for clutches and one is for the band. Your trans will just shift fairly hard.
Someone on here has to have both of these things done to their car or have experience
Old Apr 27, 2004 | 01:57 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
could you mod a tranny to the point where it shifts TOO hard, causing damage?
Old Apr 29, 2004 | 11:06 PM
batchik2's Avatar
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
i have the vette servo and the trans pak (shift kit) but i havent run the car yet with the vette servo. ill keep u posted oh how hard it shifts when i do.
Old Apr 30, 2004 | 06:31 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yes, eventually.
I had a 1978 Malibu (work car) with a 350/350, Q-Jet, headers, duals, etc. The tranny shifted hard but it was a lot of fun. After 4-5 years of daily driving (tire chirping gear shifts), the frame cracked and broke on the passenger side where the lower control arm connects to the frame.
In short it can cause damage but it is more likely to be chassis damage.
PS. That was the best and fastest work car I have ever owned, it was a sad day when it went into the junk pile.
Old Apr 30, 2004 | 09:39 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
I blocked off both my 1-2 and 3-4 accumulators as well as having a corvette servo and it shifts great! Quicker apply = less friction = longer lasting clutches especially under high H.P. I don't drive my car everyday, but when I do I drive the crap out of it and the transmission has held up for 2+ years which is great!
Old Apr 30, 2004 | 05:45 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
i put my servo in, and im hittin 2 hard. i also don't have the 2-3 flare up anymore im really happy with this mod and it was soo easy to put in too.
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
