700r4 @ Wot
Old Apr 27, 2004 | 08:13 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
700r4 @ Wot
I know that most 700R4's won't shift 4th gear at WOT. I went to the FAQ section on TGO.orgs home page and they said that there is an upshift value made by GM#8673948 ($20)and another made by B&M#70237($30) that will give you 4th gear at WOT(these parts wont give you 4th @WOT). I installed the GM 8673948 and my car still wouldn't upshift into 4th at WOT. I just wanted to let people know that fix in the FAQ section is wrong. I believe I found the correct part # after doing a search at Summitracing.com and B&M Racing. The Part is B&M #70249($115).I'll be ordering this soon for my car. Hope this help anyone looking to fix this annoying problem in there car.....Eric
Old Apr 27, 2004 | 10:35 PM
86_Dan_Z28's Avatar
Car: 86 Z28
When you installed the part did you use the red spring that came with the kit? Does your tranny have any other modifications to it like a shift kit?
Old Apr 28, 2004 | 03:25 PM
Car: 89 Formula 350
yes and yes..... those parts will only give you 4th at 3/4 throttle. If you goto B&M site they will tell you the same thing
Old Apr 29, 2004 | 10:36 AM
Pro Built Automatics's Avatar
If you modify (blocking them) the 4-3 part throttle passages in the TV plunger sleeve. Then you can in 90% of the cases make the 3-4 WOT shift, and prevent the 4-3 downshift at high speeds (85-90 mph & higher). You will need to install 2 allen plugs in these passages (use a dremel to grind allen plugs to fit if necessary for reinstallation of the TV plunger & bushing). You do not have to remove the valve body to do this, just remove the 2 bolts holding TV plunger bell crank, pin, and pull out the plnger & sleeve assembly, "modify" TV plnger, & reinstall, tighten the bolts to 95 inch pounds, reset the TV cable, and you are done.
Old Apr 29, 2004 | 10:48 PM
86_Dan_Z28's Avatar
Car: 86 Z28
How can you raise the downshift speed threshold from 85-90 to 100 or higher?
Old May 2, 2004 | 12:30 AM
86_Dan_Z28's Avatar
Car: 86 Z28
Old May 2, 2004 | 03:54 PM
What do you mean, "raise the downshift speed threshold"?
Old May 2, 2004 | 05:27 PM
86_Dan_Z28's Avatar
Car: 86 Z28
To make it be able to downshift at a speed higher than 90.
Pac J
May 17, 2020 10:44 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Damon
Sep 26, 2015 04:29 PM
6998poncho
Sep 25, 2015 02:56 PM
