those with a tremec 5 speed
Old May 1, 2004 | 02:38 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
how does the shifter fit in the center console, i went to their website and it says it will hit the ash tray
Old May 2, 2004 | 08:21 PM
rangelec's Avatar
I have a tremec in my 86. I rebuilt the shift lever a little to get it perfectly centered. Not a big deal if you have a welder. I think it was about 1/2-3/4 inch off the way it came.
Old May 2, 2004 | 08:30 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 10 Bolt 3.73
Mine (TKO) came with a shifter adapter from Forte's.
It's just a piece of 1/4" thick steel with 4 holes drilled into it.
It's about 1-1/4" long and 1" wide.
The plate bolts to the shifter stub and then the stick bolts onto the other end.
This relocates it back far enough to clear everything.
(the stick just needs to move about 1" to the rear)
-Rich-
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
topteam54
Oct 6, 2015 12:21 AM
RedLeader289
Sep 23, 2015 06:50 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
