Problem w/Moser 12 bolt housing ends!!!
Old Apr 29, 2004 | 10:02 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I ordered a Moser 12 bolt from Spohn and they've sent me a rear end w/what appears to be the wrong housing ends. On the invoice it says BIG FORD HOUSING ENDS 3/8 HOLES. My caliper bracket is comepletely different from the housing ends.The bolts holes don't match up. Both Spohn and Moser tell me I'm soppoused to addapt my braket to this housing end and I don't see how. Don't I have a 93-97 type set-up back there as far as the brakes and the housing end?. I'm I going crazy or what?
Please someone help!
Old Apr 29, 2004 | 10:19 AM
CamaroMike's Avatar
For what you paid, me thinks the rear would be going back to Spohn. Then maybe calling MOSER for big bolt in twelve bolt that fits your brakes! Cut out the middle man and pay less!
Old Apr 29, 2004 | 10:57 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Yeah, but can someone confirm that they are wrong and I'm right. Moser has a housing end that would seem to be a match.
It's a housing end for a 93-97 set-up. Do I have a 93-97 rear brake set-up?
Old Apr 29, 2004 | 11:06 AM
CamaroMike's Avatar
I would call Moser and compare part numbers between your rear and one that fits 3rd/4th gen Camaro brakes. I believe the mounting points on 3rd and 4th gen brakes are the same as long as the third gen is using 90+ PBR rear brakes.
Old Apr 29, 2004 | 11:31 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I was told by Moser you have use 93-97 rear disc setup with their rears. 82-92 setups won't fit. i had to change the backing plates to make my drum brakes fit. The bolt pattern is too small for their axle/bearing setup.
Old Apr 29, 2004 | 11:39 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I'm pretty sure you still have to modify the caliper plates to match the housing ends. If you have the big ford housing ends you must counterbore the stock backing plates, and then redrill the plate to match the 4 holes on the housing ends.
That's the way it was when I swapped in my Moser 9" package without brakes. I adapted my stock 9 bolt PBR brackets to the housing ends.
Any machine shop should be able to counterbore your plates easily, and you can redrill the holes yourself to match the housing ends. I don't remember how much you need to counterbore the plate, but I'm sure it's about 1/8" deep.
Old Apr 29, 2004 | 12:30 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I spoke to steve spoon and some guy from moser and they are denying that the exsistance of a 93-97 brake set-up on my 90 firebird. It's a conspiracy!!! My problem is that I can't send it back. My mechanic has it on a lift already. I can't tie up his lift for a week so he's gonna mod it. This is propably gonna cost me more duckets when it didn't have to. I'm very pissed off.
Old Apr 29, 2004 | 01:12 PM
CamaroMike's Avatar
Still, wouldn't a rear designed to fit your 90 Firebird that costs like 3000 bucks have plates to accept your factory disc brakes?
Old Apr 29, 2004 | 01:55 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I just helped install a strange 12 bolt in a 94 t/a, and everything bolted right up, don't know what moser does different.
Old Apr 29, 2004 | 01:59 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
That depends on the brake setup you have... On my moser 9" ford they DID NOT/Could not provide an option to use the factory REAR DISK brakes....I rewiewed the situation with the cahssis shop and I opted to buy a Wilwood big brake setup for the rear and gave that info to moser..everything bolted right up.. The only Moser factory brake options at the time were for drum brakes and I did not want to downgrade...
Old Apr 29, 2004 | 10:12 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Moser ships the rear with the ford housing ends rotated 90 degrees, so the bolt holes are top and bottom not side to side like on a stock ford. I found this out too when I recieved mine, I thought I recieved the wrong rear too. I just had a machine shop drill the 4 new holes and counterbore the backing plate. It cost me $110 to do and works great. The only diff is I used the baer rear disc setup, but it should be the same with your stock brakes.
Old Apr 29, 2004 | 10:18 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
It does...I mean Moser has it in the catalog but for whatever reason they didn't weld it on. It's the part that would be used to if you were to order a rear end for, obviously enough, a 93-97 F-Body. Since 89-92 Thirdgens got 93-97 rear brakes I would assume that's what I would get.
I figured that both Moser and Spoon would know this. Especially Spoon, since he is the sponsor here.
Old Apr 29, 2004 | 10:41 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Yeah, but wouln't these fit better?
Attached Thumbnails Problem w/Moser 12 bolt housing ends!!!-7900db_chevy_db_web.jpg
Old Apr 30, 2004 | 02:28 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Whoah, where do you get those?
Old Apr 30, 2004 | 08:07 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
What did you expect for those prices ?? A direct bolt on with any brakes fitting. You get what you pay for. I didn't think $2500 would get you much.
Old Apr 30, 2004 | 07:39 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Moser's site, is where I got the picture. I would have liked to have these instead of the Ford pieces I got. These are the pieces you get if you were to order your rear for a LT1-powered F-body.
It would have been just as easy for the nincompoops to weld on these as Ford ones. Here's a link to the pic.
http://www.moserengineering.com/cata...rd_3.8_web.jpg
Old Apr 30, 2004 | 08:03 PM
pasky's Avatar
Well, im interested in them not for the rear but for a drum to rear disk brake conversion, will these work for a ten bolt? Thanks.
Old Apr 30, 2004 | 08:36 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm not quilified to give any rear end advice. I know that my 12 bolt's housing ends looked different from the stock 10 bolt.
I think these are the stock c-clip style, like on my rear:
http://www.moserengineering.com/cata...C_Clip_web.jpg
Assuming you want to switch from drums to PBR calipers, you should first take look at what your housing ends look like and go from there. Sorry I can't be more help.
Old Apr 30, 2004 | 09:45 PM
pasky's Avatar
Hmm its really hard to tell, i know what my housing looks like but that picture isn't really good item to compare and scale to. I think from looking at it the center hole is bigger.
Old Apr 30, 2004 | 11:25 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
According to Moser's site that's the stock GM style. If your rear is the same as mine, which I guess it should be, than to convert you'll just need the caliper mounting brackets and obviously the rotor/caliper and such. There's a tech article about the swap, I'm sure.
How were you planing to use those 12 bolt housing ends for a brake swap? I'm just wondering.
Old May 1, 2004 | 01:18 AM
pasky's Avatar
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Rather than machining the drum ends, just use these
Jeremys87
Jul 14, 2022 09:08 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
db057
Aug 22, 2015 08:17 PM
sreZ28
Aug 14, 2015 07:48 PM
