I went to 2 dealers trying to find this clip and all they had was the bushings in thier diagram, if someone could provide the part # that would be great, thanks.
Are you talking about the plastic insert that goes in the clutch master cylinder eyelet? I broke mine today trying to snap on the master cylinder eyelet to the pedal. If this the same thing, I also need one!! Thanks in advance.
#20 is the clip or retainer. #25 is the plastic bushing.
Fbody.com must not like thirdgen. It seems you can't hotlink to their server. Redid it on comcast' server.
Ricktpi, Nothing came up under your link for me?
Actually looking for the gmpart # please. I also saw nothing in the link.
Sorry, the hotlink was being stubborn.
Seems it still is =/.
Can someone please get this part #, I've seen the diagrams and could only find the clip for the brakes, everything we pulled out on the diagram was a bushing when he got it from the back. I would like to go grab this piece before I head to lunch, thanks.
Quote:
Shows up fine for me at home & at work.Originally posted by pasky
All I see is "Fbody.com" sticker type graphic, mind just posting the part #?
Need this part please, need to test the new spec stage III out and the hydraulics keep popping off the pedal, thanks.
mine broke too(2 of them) so i scammed a local auto zone.
i went in told them i just bought master from them and it wasnt in the package... the manager apologized and went out back and got me one out of another ones package. then when i accidently broke that one i just bought a new master took the piece swapped it with the broke one returned it for my money back. they send them all back to the factory so its not like its gonna end up with someone else so i didnt feel bad. but its kinda a scam.
I already tried that, problem is master cylinders here are special order. Someones gotta have the part number for this thing.
I posted the illustration to make sure we were talking about the same thing. Here's the part #s
retainer 3817880
bushing 14091384
Both show good at GM PDC, so if your local dealer does not stock he can order & get in a few days.
retainer 3817880
bushing 14091384
Well thats the peice and the same diagram I was looking at, at the dealer, however We pulled out everything next to the master cylinder and they were just bushings, is the 3817880 the retainer the clip that holds it in place? Thanks.
YESOriginally posted by pasky
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
When I was using 89 Camaro pedals in my car, I just ended up finding something to make a bushing out of, and using a brake pedal clip to retain the master cylinder rod to the clutch pedal. That's another option.
Just now ended up doing that, I didnt bother with the bushing just put in a brake pedal clip and seems to work, I can't pull it off with my hand so its pretty snug.
jmd
close
- Join DateJul 2000
- LocationAridzona
Good to hear it. Originally posted by pasky
I keep one of those clips on my keychain.
