Stock speedogears?
Old May 3, 2004 | 09:11 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Stock speedogears?
Hi! guys!!
I am about to order a new speedogear to my new 3.73 gear but the man in the shop came up whith these question(You need a 15 and a 44 tooth gear. Your speed sensor will not work unless you have a 40 to 45 tooth driven gear now. What driven gear do you have now?
Someone nows what he is asking for please let me now.
Thanks!!
Old May 3, 2004 | 09:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take out the one you have now, and count the teeth. It's a little round housing in the very back of the transmission with a connector with 2 wires, right in front of where the drive shaft plugs into it.
Old May 4, 2004 | 12:11 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
OK!
So there are no way to now exept that,I mean if you now what most third gen whith 2.73 stock gears came whith.
Mybee you can tell by nowing that or is it always the hard way?
Thanks!
Old May 4, 2004 | 06:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What is the "hard way"? I don't know about any "hard way", other than guessing about stuff instead of looking, and then ordering the wrong parts.
Just look at it. It's real easy.
If your car came with 2.73s, though, the chances are very poor that you'll be able to change only the one gear to set the speedo for 3.73 gears. You'll probably have a 18-tooth drive gear, and you'll need a 15-tooth one.
If you want to make it as easy as possible, just order both gears from the dealer, that way you'll be certain to have the right ones.
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
