speedo question
speedo question
i have just put a 305 and 5 speed from an 85 trans am into my 86 firebird (was orinally v6 with automatic) i need to know how to get the speedo to work. the 5 speed has a cable and the car needs a vss . i tried the cluster with the cable driven speedo in the car but the gauges and dash lights dont work. can i use a vss from another year or model, if so what will work. or can i change the wiring to the cluster to make the 85 cluster work.
thanks
Danyelle
thanks
Danyelle
Car: `86 SS / `87 SS
You need the driven speedo gear & sleeve for an 86-up Firebird or 90-92 Camaro (with elec. speedo.) Then plug that into the original VSS wiring.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
thanks, i ordered one for a 90 firedbird with a 5 speed but it was wrong. there are 3 different ones theat are listed for the 5 speed, how can i know which one will fit. does anyone have the gm part number??
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
