help me out please
Old May 9, 2004 | 08:01 PM
86camedcamaro's Avatar
Transmission: 350 turbo
help me out please
i want to put in a 350 turbo trany to replace the 700r4 so what size tail shaft to i need to use the stock drive shaft..
Old May 10, 2004 | 04:30 AM
ede's Avatar
ede
9" i think, the longer tail shaft th350. drive shaft length isn't really that big a deal if it isn't right.
edit: should of said drive shafts can be cut down or made longer
Old May 10, 2004 | 05:22 AM
thank you for the repley because i am gonna order a new jegs 350 the one that holds 450+hp
Old May 12, 2004 | 12:48 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I'm pretty sure that tranny is the short 6'' taiulshaft.
With a 9'' tailshaft th350 you can even reuse your crossmember. All you'd really need is that crappy b&m changeover kit, and a TC. Everything else would work.
If you can afford it I'd get a new spohn torque arm. I'm going to eventually.
Old May 12, 2004 | 02:58 AM
Pro Built Automatics's Avatar
Go to http://pro-built.net/index.cfm?fusea...&productid=193 and see if this is what you want.
Old May 12, 2004 | 08:54 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
I thought you couldn't make them longer, only shorter.
Old May 12, 2004 | 10:16 AM
Transmission: 4l60e
Probuilt...do you all offer a th350 with a 9'' tailshaft?
Old May 12, 2004 | 12:35 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
I think the tail shaft is easily changed. I believe you can find them in 1980s chevy trucks and vans were the 700r4 was optional. That would be starting in 1982 and going to 1990 or so.
Old May 12, 2004 | 01:49 PM
Transmission: 4l60e
You cannot just change the tailshafts on a 6'' and 9'' th350. The actual output shafts are different sizes on the 2 transmissions.
