Aluminum driveshaft questions
Old May 13, 2004 | 03:37 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Well im thinking of buying a aluminum driveshaft and i have a few questions
first will it be worth it???
second: whats the RPO code thats JG1 i think? (like idk wtf a rpo code is i mean)
Thrid: is this a good deal?Driveshaft
Old May 13, 2004 | 03:50 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
No... If you want to buy it new get a LS1 driveshaft for 2/3 of that price:
Thirdgen 1LE aluminum driveshaft (2.75" in diameter, no dampener) http://www.gmpartsdirect.com/results...umber=10085375
Ls1 Aluminum driveshaft (3" in diameter, vibration dampener) http://www.gmpartsdirect.com/results...umber=12564004
If you wanted used....try www.car-parts.com
Old May 13, 2004 | 06:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you have to ask that question?? The answer would be NO. You will not notice any big changes. RPO code for the Aluminum Dr Shafts is JG1. Also the site you listed is overpriced, take the advice in the previous Post, if you have to have one.
Old May 13, 2004 | 09:42 PM
Borsty's Avatar
Car: 89 Trans am
will those be a direct fit??? and if so which is better? the lighter one with no vib damp or the heavier one with the vib damp?
and with the jegs one, it seems to have higher quality. so it might be worth the extra $.
Old May 13, 2004 | 09:57 PM
pasky's Avatar
The ls1 driveshaft is ighter than the 1LE and has a dampener, both are direct fits. Ls1 shaft is the better way to go.
Old May 14, 2004 | 09:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I too was going to buy one from jegs, I didn't realize a GM one was better and cheaper! Thanx for the tip
Vintageracer
Jan 10, 2020 05:33 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
redmaroz
Aug 16, 2015 11:40 PM
z28addict8490
Aug 7, 2015 08:48 PM
