Mystery Noise
Old May 14, 2004 | 09:03 AM
smoove2022's Avatar
Mystery Noise
Okay I know this forum is for f-bodies, but I figure most manual tranny's operate the same so here it goes...
My 222,000mi 93 silverado (4.3v6 2wd 5-speed) is making a grinding noise when engaging gears. It happens like this:
The grind is comming only while letting off the clutch pedal for engaging a gear. So when starting from a stop for example - The stick is in the 1st gear position and the clutch pedal is depressed (truck is still). As I let out the clutch pedal and depress the throttle and the truck starts to move, it will grind (sounds like mssing a gear) untill the gear is completely engaged and my foot is off the pedal. Unless I heel-and-toe it just right and apply only light throttle, then it won't grind. The sound is worse when I rev the engine higher. At no other point in the transmission operation does it grind. I feel no shaking, nor do I hear any squeeking or other strange sounds.
Any thoughts? Low tranny fluid? Pilot/throw out bearing? Synchro's?
Old Dec 29, 2004 | 09:03 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I know this is an old post, but I am having the same problem as of recent. Did you ever fix the problem that you are having? Just wondering
Bill
you can drop me an email at weberwd@gmail.com or just reply here. Thanks again
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Randomtask2
Sep 7, 2015 05:06 PM
