assemby of a moser 9 inch ?
Old May 15, 2004 | 12:00 PM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
Have any of you guys pieced together and installed a 9" and if so how tough is it ? Just the third member, spool bearings, pinion, ring gear..etc. Installing the housing, axels,brakes, etc.etc. i can handle myself.
I've got all the components, just not real sure if this is something that i can do myself, or if i should send it out to be done.
Any advice is "mucho" appreciated !
Bc
Old May 15, 2004 | 12:38 PM
ede's Avatar
ede
no harder than any other rear end, i've not done enough to do it without thinking more so than gm rears. the pinion shims always seemed backwards to me but i learned o ngm.
Old May 16, 2004 | 04:01 PM
Mandangelo's Avatar
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
The spool bearings and pinion shim are my biggest concerns, ive heard that you need a bearing press for the spool bearings..?
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
