ATF leak at transmission speedo cable?
Old 05-15-2004, 07:55 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I've had a leak ever since I bought this car last fall so I cleaned up everything so that I could tell where it's coming from. It looks like it's coming out of the part where the mechanical speedo cable connects to. It's coming out where the silver two prong fork is holding something.
Is there a seal in this location?
Joe
Old 05-15-2004, 10:38 AM
ede
ede's Avatar
yep there's a seal at that location
Old 05-15-2004, 06:36 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Well I started to remove everything so that I could get a new o-ring for the speedo gear housing and I noticed something. The housing is all messed up. It's real brittle and it's crumbling into many pieces. DOH! No wonder it's leaking!
Ok, I need a new speedo housing or sleeve, whatever they call this thing. Of course, nobody stocks this type of item so I'm just going to order it from rockauto.com, gmpartsdirect.com or somewhere. I just need to know what to get. So far I think I need this part.
ACDELCO # 12338069
RETAINER, SPEEDO DRVN GR SLEV w/4-SPD A/TRANS(MD*)
Is this what I need?
Part where the metal fork holds in and the speedo cable screws onto.
Old 05-15-2004, 10:27 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
how many teeth are on your driven speedo gear? I have a sleeve if it's 41 to 45 teeth.
Old 05-16-2004, 03:25 PM
Nordbert's Avatar
This site has some speedometer gear info:
http://www.bowtieoverdrives.com/cata...BCAT&CATID=DA2
Old 05-16-2004, 06:31 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
I'm confused, do I need a sleeve or a housing? Or is that the same thing?
I need the platic part that the retainer holds on and where the speedo cable threads onto. I've seen other posts where others have bought a new one and it was aluminum.
Old 05-16-2004, 06:52 PM
jmd
jmd's Avatar
not 100% on the 700-R4 / TH350-C gears, but I know that I have pulled 200-4R parts with a steel sleeve / gearshaft combo, and plastic sleeve / gearshaft combo. Not mixed. If you have a plastic gear, plastic may be the way to go.
smokingss
LSX and LTX Parts
03-03-2016 07:40 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
formula_novice
08-18-2015 08:48 PM
Exxon Limited
08-09-2015 08:13 PM
beachrodder
08-07-2015 04:27 PM
Quick Reply: ATF leak at transmission speedo cable?
