T5 speedo gear sizes and colors
Old May 15, 2004 | 05:13 PM
Ratchet's Avatar
Does anyone know if there is a list somewhere that tells you the size and color of the drive and driven gears for the T5 speedo drive? The T5 I have needs to be calibrated to match stock diameter wheels and a new 3.27 rearend. The driven gear is white and it has 19 teeth. The drive gear is blue and still inside the tranny and I can't get a count on the teeth. Anyone know the tooth count?
Ric
Old May 16, 2004 | 10:23 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Drive Gears:
Purple - 7 #14071731
Red - 9
Driven Gears:
Red - 18
White - 19 #14090592
Light Blue - 20
Orange - 21 #14090582
Gray - 22
Old May 17, 2004 | 12:24 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Gray - 22
This is exactly why I ignore colour every time. The majority of 21's I've seen in T5's have been a green colour. The 22's I've seen have been red.
7 on the lower left, 21 on the right:
Old May 17, 2004 | 08:05 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
hmm, the 21 tooth i have is orange, but its 29 years old. im not sure when they discontinued them. all that i have seen have a metal sleeves
Old May 18, 2004 | 09:09 PM
Ratchet's Avatar
Thanks for the info:
Based on that information and the caculator here http://www.hanlonmotorsports.com/t5speedo.asp
I will need to use an 18 tooth driven gear to get things working
right. Anyone know what speedo housing I have to use with an
18 tooth driven gear. I understand that changes in the number of driven teeth require one of two different hosings to get
the distance between the gears to work right.
Ric
Old May 18, 2004 | 09:22 PM
jmd's Avatar
jmd
Originally posted by Ratchet
I understand that changes in the number of driven teeth require one of two different housings to get
That's true for th350-c / th250-c / 700-R4 stuff. I don't believe that's the case for the T5.
Old May 18, 2004 | 10:07 PM
Ratchet's Avatar
GM dealer asked me which part number I needed. two listed for T5.
Ric
Old May 18, 2004 | 10:11 PM
jmd's Avatar
jmd
Probably for VSS, or cable drive (Camaro had cable through 89; `Bird through 85.)
69 Six Pack
Oct 5, 2015 07:51 PM
Linson
Aug 21, 2015 02:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
