need this item identified on my t5
Old May 16, 2004 | 10:31 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
see the attached photo below. this is on the v6 t5 in my 84 sport coupe.
look at the metal bar that is bolted to the bottom of the transmission, and is directly below the driveshaft.
specifically, what is it? am i looking at problems if i don't reinstall it?
thanks in advance
Old May 16, 2004 | 11:40 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's supposed to be some kind of dampener or some other such thing. I removed the one from my 83 SC when I replaced the trans, and noticed no ill effects.
Old May 16, 2004 | 11:52 PM
johnyIROC's Avatar
Yeah... I've seen it on our old V6 too... the focker weighs like 50lbs!
Old May 17, 2004 | 01:06 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My friend with an 84 v6 vird was backing down his driveway one day and hit something and just decided to keep going, ripped the freaking weight right out of the tailshaft of the transmission. Broke off one or two mounts, too. Tossed that thing and never looked back.
Old May 17, 2004 | 05:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I can't realy see it for sure in your pic, but I think I know what you mean even without the pic, but I image-processed it anyway; do you mean this thing here?
If so, the others are exactly right, it's a vibration damper.
Disposable if you can tolerate slightly increased vibes. I suspect the factory installed it on the 6-cyl cars because thy often got higher gears (more vibes), and the kind of people who would have bought a 6-cyl car new would have been less willing to put up with vibration (since they obviously had no interest in performance).
Old May 17, 2004 | 05:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OOOoooops.... how about the pic?
Attached Thumbnails need this item identified on my t5-t-5-6-cyl
Old May 17, 2004 | 04:58 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
thanks everyone. looks like i'm not bolting that back on
how does the underside of the car look? you can see where i've scraped off some grease and oil to reveal the undercarriage.
car has approx. 166k miles.
F-body-fan
Jan 12, 2023 01:49 PM
Magman
Aug 2, 2016 08:32 PM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
Linson
Sep 21, 2015 01:08 PM
