speedo needle?
Old May 17, 2004 | 08:08 PM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
speedo needle?
Bought a 145 mph speedo for my car and was cleaning it up when the needle broke off the housing. Is it possible to take the needle off my 115 mph speedo so i can switch out face plates???
Old May 17, 2004 | 10:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes, but if the sweep of 0 - 145 is 270 degrees and the sweep of 0 - 115 is 270 degrees, just switching faces onto the olde speedo won't do it.
Speedometer repair can be tedious but doable. The parts to do an accurate correct-parts-no-calibration face-plate swap are typically discontinued also.
Old May 17, 2004 | 11:29 PM
iroczz89's Avatar
Engine: 383 tpi
thanks for the reply. Exactly how do you remove the speedo needle without breaking it?
Old May 17, 2004 | 11:34 PM
jmd's Avatar
jmd
Some kind of a forked lever. tack puller, cheap restaurant fork, etc. I've never broken a needle or spindle but like I said... tedious & I've seen others break them.
69GTOby
Apr 18, 2016 02:34 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
TrevinE
Sep 14, 2015 03:20 PM
